drill motor wheels
  • drill motor wheels
    hi everyone
    my 100mm robochallenge wheels and slightly to small for my body shell yet 125mm wheels will be too large, can anyone recomend me some around 110mm that can take having nut inserts put in? or by te offchance if anyone has any really worn down 125mm?
    failing that, anything else you can recomend? oh, and i want to avoid putting bike tyre on if possible unless its the cheapest and/or easiest way to solve my problem
    Re: drill motor wheels
    Try banebots wheels, If they don't do the right size use tyres
      i might have to resort to bike tyre again
        Bike tyres would be cheapest, just get the bike tyres for free .
        Banebots seems to only do 98 or 124 so not much luck there
          You might be able to get a 125mm or so wheels and turn off some of the rubber so that they are the right size
            Put the 125mm wheels on the drills and run the drills at top speed then press a file against the rubber to quickly remove the desired amount of tread. A course wood file would probably work best.
              Good idea I tried this and managed to blow the speedo
                i think ill just stick some bike tyer round, much easier and cheaper
                  Lathing down a set of Blue Wheels ain't difficult with the right cutter.
                    Matt I wasn't saying don't do it, i was saying do it straight off the battery not through the speedo
                      its the cheaper option for me since i have a spare tyre and i would need to buy the new wheels first
