size limit
  • size limit
    feather weight size limit, what is it
    Re: size limit
    there is none
      Re: size limit
      It's exactly how big you can carry * how big the door is.
        Re: size limit
        According to the mentorn rules, and if I recall correctly, any robot between featherweight and superheavyweight has to be between 1.4m*2m in surface size. Height wasn't limited.
          Re: size limit
          Seraph a feather was 850mm wide 1,050mm long and 500mm high. but it is a bit smaller now. in my view the bigger the better
            Re: size limit
            you have to remeber realy the only limit in feather weights is 13.6kg (30lbs) in old money
