Pneumatics questions
  • Pneumatics questions
    I was wondering whether anybody could help me? I can't quite figure out a few things.
    In my stores is two pneumatic rams, a buffer tank, a trev reg and a solenoid.[*]The Trev reg and large Ram I don't know the sizes of. The ram has push fit studs in but has no particular markings, just red and the number 8. The port beneath, by deduction from the cylinder bore, should be 1/4.[*]The smaller ram definitely has a 1/8 with no studs.[*]The buffer I was told is built with a 3/8 stud in it.[*]The sol valve has 3/8 ports with no studs.
    Secondly, what metric pipe would I use for each port, for high flow rate?
    Thirdly,How on earth do you refill the paintball bottle?
    Here's it so far, but it needs work
    Re: Pneumatics questions
    1. a number on the push fit is usually the od pipe it'll take. for that size ram i'd guess 1/4 aswell, if you want to be sure of the port size just unscrew the push fit and check.
    2. i'd use either 10 or 12mm for the pipes going from buffer to valve to ram, the tube from the regulator to buffer tank you can use smaller like 6mm.
    3. with a screw top paintball bottle refill the same as you would with any other screw top bottle. assuming that's the reg i sold you ages ago you shouldn't need an adapter for filling up your paintball bottle
      The bigger ram is a 40mm bore. The fittings in it have a 1/4 thread and will take an 8mm pipe. Obviously you can change these for whatever size pipe you need
      The fitting in the buffer tank is 3/8 thread and for an 8mm pipe. Again you can change this for whatever you want
      The biggest easily available pipe using push fits is 12mm (you can get bigger though). We used to use 12mm on Hydra so it's probably overkill for a feather.
      An 8mm pipe would probably be fine. I know you have a 3/8 valve but the reality is that this will not be fully open before the ram has finished firing. You can use the flipper calculator on the Hassocks Hog Page www.hassockshog.co.uk which should show you the difference between various pipe sizes.
      Take it to an event and get someone to show you how.
