got some teathing problems, anyone any help?
  • got some teathing problems, anyone any help?
    hi all
    with my electrics today, im having a few issues
    first, on channels 2 and 3 of my giantcod rc gear, with both motos plugged im, only one will resopond to the RC commands, the other just stays running yet if they go into channels 1 and 4, they run fine, but that involves them running of separate sticks
    i need the left stick for my actuator and need both motors to drive on the right stick, anyone got any ways how i can achieve this and counter the issues im having?
    Re: got some teathing problems, anyone any help?
    What ESC's is it you're using again?
      electonize 15a with 25a fuses
        I can't find it on a quick search, but does the manual tell you which channel does what? Is it the same as Spektrum for example?
          i didnt get one with it
          channels 2 and 3 worked for drive for me in my last bot and i used the exact same set up but they just wont work in this one
            ch1 and 2 is drive, 3 is the throttle
              right, sorted that, but my actuator is acting up
              the relay is on, its showing that its active, yet the actuator does nothing. i texted it on a 12v drill battery and that also did nothing, but im not sure if the battery is dead
                Maybe it doesn't have its phone on it?
                  hello IT, have you tried turning it off and on again
                    I'll be annoyed if he doesn't
                      Has anyone got an idea of how I can test it with spade connectors on it?
                        touch the spade connectors to terminals of a battery
