servo esc
  • servo esc
    can u use the servo micro switch esc ? like on martsards video
    Re: servo esc
    Yes, I used it but you need a failsafe.
      Re: servo esc
      is that in the radio gear?
        Re: servo esc
        depends what your using
          Re: servo esc
          how could u do it else were?
            Re: servo esc
            plug in fail safe.
              Re: servo esc
              and the removable link can it be under a hinged flap or must it be on show?
                Re: servo esc
                It can be under a hinged flap, but you must be able to access it without the use of tools. So if you can just lift the hinged flap up with your fingers, it's fine; if you have to use a screwdriver to undo a bolt or screw to lift it up, it's a no-no.
                  Re: servo esc
                  instead of a hinge maybe use a stiff bolt that attaches the cover this can be rotated out the way to show the link
                    Re: servo esc
                    or get a magnet so it stays down but u can lift it up
                      Re: servo esc
                      or use strong velcro
