It freezes up the reg. It takes some time before the reg will function properly again. A solution is to stick a coil of thin copper tube (large surface arena etc) between the bottle and the reg. That tends to give the CO2 enough opportunity to change state into a gas.
I can supply 1 ali 1.1 kg Project II bottle, or an brand new 1.5 kg bottle , with the same dimensions, unfortunatly, that 1.5 kg bottle is a steel one.
But why such a big bottle for a featherweight? the cheaper, lighter and simpler solution is to use 1 or 2 20 oz paintball bottles.
The connection is the classic 5/8 UNF 18tpi CO2 attachment. Size, 101mm diameter and total length 420mm. The Knob is a small 5 lobbed round one, diameter about 50mm. Way to big for a feather. Even the ali one weights over 1.8 kg.
Also, I was intending to use this as the bottle for the resurected Project II. Combined with the basic cost, and the P&P, it is more intersting to buy one in the UK. Dont forget Im over the channel.
