Re: Teething issues
It's all running fine now, got two Argos motors each side at 16.8v running in parallel from each speedo. Wiring is fine (not amazing but adequate), both sets of power wires from the speedos go into a connector block with a deans connector to the battery. This is testing set up anyway, gotta add the power switch and LED. Just think it was one of those things! One thing I may do is put some rubber washers in the speedo mountings to isolate from vibrations. I've now set the electronize's to highest frequency setting and 125% speed and all seems fine
