Re: Scorpion XXL
Are you driving using BOTH channels on the right stick and have you currently got the bot working like this ...?
To check everything is fine ...pre-mix ...take your transmitter and rotate it 1/4 turn clockwise ... your bot should follow the stick movement vertically and horizontally and drive correctly with the transmitter twisted like this.
Everything OK?
Then turn on the mixing..... EITHER the XXL's mixing ...OR the Transmitter mix....that will probably be Delta Wing an Ele / Ail mix.
Everything OK?
