scorpion xl
    Re: scorpion xl
    You had it working, I saw the video on youtube, can you remember what you've done to it since then ?
      Re: scorpion xl
      i found on the flip channel the black wire had come off, but i didn't use it anyway could this cause the problem?
        Re: scorpion xl
        never mind ive sorted it now
          Re: scorpion xl
          ummm hope no one minds but what should i do with an exploded nimh cell? ive buggered one off mine:
          http://www.youtube.com/watch?v=iSN7-bjccQ4
            Re: scorpion xl
            How did you end up sorting this Harry? I think mine is now doing the same
              Re: scorpion xl
              what the esc or the battery?
                Re: scorpion xl
                The ESC. I seem to have the same problem you had with the light flashing as if it is in calibration mode when the jumper isn't on.
                • #23
                  Re: scorpion xl
                  i found it was i needed a separate rx battery, and that my battery terminaly was a bit loose
                  • #24
                    Re: scorpion xl
                    Ahh ok, i'm using a separate battery at the moment, it might be a bit dodgy though so i'll check the battery terminals, cheers. I'm guessing you mean the terminal on the ESC?
                    • #25
                      Re: scorpion xl
                      yes
                      • #26
                        Re: scorpion xl
                        Great, will give that a try, cheers
                        • #27
                          Re: scorpion xl
                          sorry for the rather large bump, i didn't think it warrented another thread.
                          there seems to be a worrying gap between the motors when i push the stick forwards, one seems to start quicker than the other so i end up going in circles, any ideas whats going wrong?
                          atm im just giving everthing a charge to see if that helps but it tried it with a couple different batteries.
                          thanks
                          • #28
                            Re: scorpion xl
                            Have you tried recalibrating the ESC to your transmitter?
