Hobbyweights anyone?
  • Hobbyweights anyone?
    FRA rules raptors (basically GRA)
      There are no FRA rules for raptors.
        thats what i thought.
          ok, until told otherwise, raptors will be feathers, but half the weight. I had proposed restrictions on motors etc, but as the rules are not yet passed by the fra, well have to assume they are generic like all the other weight classes.
          This is of course just my take on it, and so if the FRA agree, this is how I will run the raptor class at the event.
          (Message edited by jamesb on November 23, 2006)
            The GRA rules are restrictive on motors and materials used. But strangely enough, not on batteries.
              Mario- sent you an e-mail. Please reply, tah.
                Raptors in the GRA are restricted in size of motor, the max size is equal to a mabuchi 755, and max voltage is 12V. No Neodimium or kobalt motors, and no adjustable brushes from anything higher than 540 motors.
                The robot is not allowed Ti or other expensive materials.
                  Hi,
                  it is like leo told: the GRA-raptor-rules are restrictive only on motors (biggest motor are the Mabuchi 750 ore equal to this motor) and the max. voltage to power weapon and drivetrain is 12V. Higher Voltage only to power valves. But no restrictions to expensive materials like Ti, you can youse everything. You can find the rules here:
                  http://forum.roboteers.org/filebase_entry.php?entryid=6&sid=e616f8396c5050019 f13adfa45f58a5chttp://forum.roboteers.org/filebase_...396c5050019f13 adfa45f58a5c
                    Hi,
                    Here´s some pictures of my old and now retired hobbyweight:
                    http://www.robosota.fi/foorumi/viewtopic.php?t=848http://www.robosota.fi/foorumi/viewtopic.php?t=848
                    Weapon: Lifter driven by 550rpm/12V drill
                    Drive: 12V drillmotors with 24:1 gearboxes and 3 Colsons
                    Armor: 4 and 8mm polycarb and 1mm steel and 4mm alu
                    Bot weighted just 5 kilos so I used some steel offcuts to bring weight up to ~6 kilos.
                    Also started to build new hobbyweight few days ago. First pictures can be found here: http://www.robosota.fi/foorumi/viewtopic.php?t=1039http://www.robosota.fi/foorumi/viewtopic.php?t=1039
                    Four wheel drive with active weapon driven by 9,6V Panasonic drill.. And yeah, I know, 3/8 chain is way overkill for hobby. Weight will be very close to 6 kilos when ready..
                    Oh, and there´s also pic of my new 450g drumbot in profile.
                      Nice work! How does the arm on the older machine retract? Does it just fall back down when the drill winds back?
                        There was just some elastic bands to pull lifter down. Not very good solution as they snapped in every fight..
                        Also it´s not very clear in the pictures, but lifters gearing was variable between 13:1 and 10,8:1 (not including drill gearbox).
                          nice... dont suppose your robot can make it to my event in april? we have several raptors competing
                            All three of those machines look impressive Juha, Keep up the good work!
                              Ewan, here it is.
                              (Message edited by leorcc on May 21, 2007)
                                Cheers Leo, but I was implying a wholly different section - this topic is still within the Featherweights thread divider.
