where would I get wire and connectors, and which type?
electronics
Re: electronics
Connetctors: use deans they're the best http://www.giantcod.co.uk/deans-style-u ... p-208.html
Wire: anywear I get mine from RS
Re: electronics
I think you would only need Y leads if you were running 4wd with your speed controllers controlling 1 left and one right wheel each. Is that whats happening? In which case I think giant cod is the place for decent priced servo y-leads.
For the batteries just use deans connectors and make a parallel circuit with them, no need for any special sort of connector or lead to do that.
Re: electronics
The DC voltage we run doesn't have much to do with the wire gauge, it's the amperes that decide.Originally posted by gizmowhat wire gauge do I need if I'm running 2 18v bateries in parrallel
In the industry , 10 amperes per m² is seen as on the edge.
So, how much amps do you expect to draw?
