what would be the optimum thinkness of hdpe on a featherweight rambot. taking into account, weight, price and protection
hdpe armour thickness
 Re: hdpe armour thickness
 We had 13mm HDPE on Bitza and LH (after three rounds mind) managed to crack it, as well as put some good 5mm deep gouges in it.
 Explosion on the other hand has very thin HDPE which makes in malleable, meaning it takes hits very well, but that it also down to their Hardox frame its built on.
 So remember how you mount it is also important, and thickness isn't everything with HDPE as it can always crack.
 Theoretically yes. The standard rule for overvolting motors is that 150% is the maximum safe value (so for a 12V motor this would be 18V) but you can never be totally sure when it comes to running components beyond their specification. I've got a pair of the Argos drills but I haven't used them yet. However I will be running them on 19.2V (slightly over the 150% rule) so will see how they perform then.
