There is no set rule as the brand or design that a removable has to be. It has to kill all power to the robot when removed. However there are a number that have become somewhat of a standard.
The two that jump to mind are anderson connectors (the small 30amp ones) and deans connectors. Solding a loop of wire across the terminals of the male connector and have the female connector solded into the connection to your batteries is the easiest method.
the parts that i need to be cut have been measured and have been sent off to my uncle who will cut them out for me (because i cba to do them my self with a saw and he has a band saw so...) anyway they will be done soon (next time i see my uncle) so stay tuned!
sorry for the late delay but here is the chassis the paper represents steel or aluminium soooo
gunna get the metal a screw it all together any ideas for metal for the scoop and top and bottom?
