Chargers
    Re: Chargers
    Sorry i've been holding back on replying to you here, I just plugged in my Dx6 lip into the charger and it seems to be charging it . I'm going to test the NiMH's on it tomorrow and see if they work, maybe it was just playing up for no reason the other day there.
      Re: Chargers
      Bizarrely, the charger now seems to be working, sorry for keeping you waiting on a response Terry, i'll just leave it for now but if it takes another funny turn before Edinburgh and you still have that charger I will let you know.
      Just making sure i've got this correct too, if I was to wire the charger to be able to charge 2 identical batteries in series (I think i'm correct in saying it should be done in series) each one being 9.6v 3300mAh, I should programme the charger to charge it as if it is charging one 19.2v 3300mAh battery. Thats right isn't it? Just making sure before I start a fire .
        Re: Chargers
        yup you are correct, series charging, as long as the charger can handle the voltage, is fine with identical cells
          Re: Chargers
          Cheers Gary, I don't know if it goes up to 19.2v, but i'll check that tomorrow.
