posibly a stupid question...
  • posibly a stupid question...
    i have some speed controlers in my feather weight that run of 7.2v each i have 2 7.2 batterys that are way under powered for a feather but they seem fine for testing.
    my question is this: how can i run both speed controlers of one battery? would some kind of adapter lead do it ??
    the reason for this is so i can just have one removeable link.
    thank you for reading this,
    harry.
    Re: posibly a stupid question...
    use a chock block and put both positive output together and both negetives (ground) output together.
    And then have a battery in
      You wire your batteries in parallel through a connector of some kind like so, put the removable link on one of the wires coming out of the connector and then put the speedos in paralel.
