Bigger wheels
  • Bigger wheels
    Does anyone know where I could get some bigger wheels (say 150mm) with a nut insert to attach to a drill motor?
    Re: Bigger wheels
    robochalange do 125mm wheels
      Re: Bigger wheels
      They don't contain the nut inserts though?
        Re: Bigger wheels
        You have to email them to get the 125mm with nut insert. You could just get some 3/8 unf nuts and whatever wheel you want and make your own
          Re: Bigger wheels
          make them yourself, get some nylon or hdpe, cut into circles, drill a hole in the middle, heat up and insert a nut then screw some tyre tread around the outside, job done
