Best way to attach threaded rod to a drill motor
  • Best way to attach threaded rod to a drill motor
    whats the best way to do this? weld it on or what have other people done?
    cheers
    Re: Best way to attach threaded rod to a drill motor
    either by using a shaft coupling or by taking the gearbox to bits, smacking the output shaft out of the plate with the three gears in it and then welding the new one in place. You could try welding it straight on but you may have alignment issues.
      The best shaft coupling would probably be a custom job by Kenny or someone. Maybe with a couple of grub screws at either end to locate/hold it in place and then, if you don't foresee any need to remove it, weld the ends of the coupling to the drill shaft/threaded rod (keeping in mind possible heat distortion leading to mis-alignment)
      An alternative would be to use the drill chuck. Put the threaded rod in and tighten the chuck, then to stop the whole thing coming loose, drill straight through the chuck and rod in a couple of places and secure with bolts. Most cheap drill chucks have a 10mm diameter capacity, so maybe a couple of M4 or M5 bolts.
      What threaded rod are you using? Because a lot of rods from car scissor jacks are bigger than 10mm so you'd need to turn an end down to get it to fit in the chuck, whereas threaded rods from the basic work benches you get in B&Q, Homebase, Wilkinsons etc seem to be the right size (judging by my work bench anyway).
      I'm toying with the chuck method for the Carcinus rebuild, if I decide not to butcher an actuator instead.
        Wouldn't it be possible to drill out a hole in the threaded rod (car scissor jack type) to just a tiny bit larger than the drill shaft, place it over and drill straight through them both and secure with a bolt or pin?
          You can get any size threaded rod off the shelf, I can make you a coupling if you want. I can mill a flat onto the motor shaft and threaded rod and just put grub screws in the coupling. Doesnt matter what size threaded rod you use then I can just make the coupling to fit.
