rubber to metal bonding companies
  • rubber to metal bonding companies
    hi guys
    i'm looking for a company which can bond rubber to some ali wheels ive made, like Dave Moulds has done for 540. I have asked the people he used but their price was too high
    i've looked around and contacted a few others but still high prices
    does anyone know of any places i could try?
    cheers alex
    Re: rubber to metal bonding companies
    You could try doing it your self.
    I know some builders that made their own and achieved good results, specially Nick, from Australia, Scissorhands builder. There are loads of information on his forum topic: http://www.robowars.org/forum/viewto...asc&start=2460, beware the topic is huge and information about wheel casting is mixed with lots of other stuff.
    Nick is a very accessible person, so if you need just drop him some lines on the Australian forum.
    I intend doing something similar for some of my designs. The price is better if you intend doing lots of wheels.
    Just buy PU (Polyurethane) resin and the appropriate hardener, make some molds and start batching
    Cheers,
    Eduardo
      I thought the price that dave got was reasonable bearing in mind that it's a custom job.
        But Alex is a fully fledged fresher now, and as such, every penny saved is a penny towards booze :wink:
          hahaha very true Jamie
          Yeh the price per wheel Dave got was good but you only get that price with 6+ wheels i only have 2 because of which the price shoots to £85 :x
          so i'm still on the bargain hunt
          cheers all for posts
            The Nipper guys bought the stuff and made the last set themselves, but you need to make the moulds yourself. Think they said they got it from RS but that could be wrong :P
              cheers alan
              gonna look into some of the diy stuff
                Your best bet is to talk to Jeroen.
                He showed me some polyurathane you can buy off RS for quite cheap, Then you'd just need to make your self a mould to put the wheel in central and pour the rubber around.
                Joroen showed me a picture of the wheels John reid has made, He just made the moulds out of some wood and cut a hole in the middle with a hole saw. Simple enough to do, but can be messy.
                  Just thought I would add a link. I bought some polyurethane to make some antweight mecanum wheels from here about a week ago:
                  http://www.mbfg.co.uk/category-143/3800.html
                  It worked out cheaper than ebay for me. Does anyone have the link the stuff from RS I would be interested to see what they have, I couldn't find it with a quick search.
                    The rubber i used from RS is Devcon Flexane 60. And the primer is Devcon FL-10.
                    http://uk.rs-online.com/web/search/sear ... &R=0692845
                    http://uk.rs-online.com/web/search/sear ... &R=0692895
                    In the link below I have some pictures of the wheels I made. I used gypsum but it was tough tp remove it from the rubber. Maybe spraying some sillicon rubber on the gypsum would have helped. The blue mold is sillicon rubber but it cured too fast to make 5 negative moulds at the same time. That was a waste of money and the gypsum was a cheap alternative afterwards After removing it from the gypsum i grinded them on a lathe to make the wheels smooth, round and concentric with the bearings.
                    http://picasaweb.google.com/Jeroenvdlo/Firestarter1#
                    I hope I will have permission from John Reid to post 2 of his pictures in the link below.
                    http://picasaweb.google.com/Jeroenvdlo/JohnSWheels#
                    He used wood and sillicon spray and it seemed to work well. I am still curious how long the wheels lasted in combat.
                      cheers guys
                      thinking over the options now
                      does anyone have an email address for the big nipper guys?
                      cheers alex
                        We used Devcon Flexane 80 for our wheels but it is expensive and not so good so am going to try something cheaper next time http://www.mbfg.co.uk/category-143/3808.htmlThis looks like it would be ok. I made a mould for 4 wheels at once out of aluminium and after they set just turned it over then gave it a tap with a mallet and they fell out.
                          Pm sent Graeme
                            if i were to use a home made option how do i make it stick to the hub and not to the mould? and stop it doing the opposite?
                            cheers
                              right bit of bump but finally got the wheels sorted
                              £30 for the pair inc delivery
                              pics below
                              http://i737.photobucket.com/albums/xx17 ... 090163.jpg
                              alex
