Hi all
I'm trying to work out the ratio of my linac
currently its setup in the 90 degree position, however im looking at changing that so the motor will lie flat onto the main linac body
to then transfer the motor motion to the screw i plan to use timing belts and pulleys. but i want to stick with the same ratio if possible but the 'gear box' is a worm gear to a (i think) Helical gear.
my question is how do i work out the ratio between them ??
thanks alex
thanks alex
