whats needed for an electric lifter/axe?
  • whats needed for an electric lifter/axe?
    i know it sounds funny but whats the best set up for an electric lifter or axe on a budget that can give ok results, without breaking the bank?
    thanks
    matt
    Re: whats needed for an electric lifter/axe?
    for lifter cheap actuator then a lifting arm for an axe get a cheap scooter motor some chain and sprokets or gear it to the ratio you want with an axe arm bot are hard to do well but easy to start with
      does anyone have a photo of there set-ups so i can get a good look at how its done?
        http://www.robowars.org/wikka/ElectricAxeWeapons - A good electric axe guide
          thats a good help, thanks!
          anyone got a good one for electric lifters?
            I posted a diagram of how the lifter in Kaizer worked, along with a bit of explanation in an old thread a few months ago. I'll see if I can find it.
            EDIT: Found it, although just for reference, the forum search capability is crap.
            viewtopic.php?f=111&t=3440&start=15
            The last two posts of that thread. The first one gives a brief explanation of how the lifter in Kaizer worked, and the second one is just a couple of pictures to help aid the explanation.
            It's worth noting that if you use a commerical actuator as opposed to the drill motor setup in the diagram, the principles are exactly the same. The only difference is that a commercial actuator moves like a pneumatic piston, so you've got a bit of tubing moving in and out, whereas the drill motor has a nut sliding along a fixed piece of threaded rod. If you make a lifter using a commerical actuator, the end of the piston takes the place of the nut of the drill motor setup by being attached to the linkage arms. Hope that's moderately clear, I feel I'm mushing my descriptions slightly...
              I'm building my first robot with a lifter. I'vegot all the bits for it but havent got round building it.
              jamies way is the way i'm using , it costs around £50 for the motor, studding(or threaded rod), bolts and ESC
                which one would probably be cheapest too build?
                i am doing robot combat on a budget! lol
                  ive owned both and i think an axe is more fun you have to be more tactical with a lifter so if you like tactics go for a lifter if you like hitting things that get in your way go for an axe in terms of price lifter is probably cheaper but more work than a simple axe mechanism if you go for a lifter i have a actuator and servo control unit available that would be a great starting piont
