is the standard wiring up to the job?
Argos 12v drills
Re: Argos 12v drills
just started testing and got a few questions:
1. what resistor shall i use as an interference suppressor on these motors?
2. sounds a silly question but do i have to match the grub screws exactly so that the motors spin and brake at the same speed?
3. whats the best way to secure robo challenge blue wheels? loctite?
1. it's not a resistor, it's a capacitor. Not sure what size you'd use and whilst it's a very good idea to fit them you should be ok without if you're using 2.4ghz radio gear. That's not to say you wont get interference because it can happen. We have had a few issues with antweights and also it seems with Dantomkia on the weapon fire side of things because we got lazy.Originally posted by Danjr1just started testing and got a few questions:
2. Never had a problem with driving relatively straight without considering it but without a gyro they don't drive perfectly straight anyway. If you're concerned by this then you could use the o ring method
3. Personally i'd recommend against loctite and just try and use the reverse thread screw which comes with the drill itself. Mainly beacuse I'm fed up having to cut the shafts and drill out the wheels and re-tap them
I did with our first feather, Pete said drive to the middle of the arena and well..............never got there!!Originally posted by typhoon_drivernever needed to loctite a wheel and never had one come off. I've had battles where the bot has come out and the wheel has been able to move back and forward along the thread but a quick tightening and it's fine.
