pro peak constellation charger
  • #31
    Re: pro peak constellation charger
    It's just stopped at 4431mah at approx 6v so that pack is fine
    • #32
      Both the 12v and 4.8v packs are accepting the charge and discharge fine to within 200mah of each other so it ain't the batteries?
      • #33
        All sorted! Thank you all for ur help
        • #34
          What does TRK mean in the top left hand corner once it's finished charging?
          • #35
            trickle charge (slow charge just to keep it topped up)
            • #36
              Weird. It charged to half it's capacity then Switched into that mode. It's never done that before
              • #37
                Probably means the battery was already half-charged. I don't know if it's the same with all chargers (only recently got into fancy chargers) but it'll put in as much as there is room for and then trickle or stop the charge. This provides a good indication of how much has been drawn out of your batteries in a battle.
                For example, if you have a 3000mAh battery and it only charges to, say, 1000mAh after a fight, that's how much you took out of it in that fight. So your battery still had two-thirds of its capacity remaining.
                At least I think that's how it works...
