Bosch 35watt Motors
  • Bosch 35watt Motors
    Hi
    I have been looking into these. The seem perfect for what I have planed. But after talking with another roboteer he says that most people use the 12v motors at 24v to get any speed. Is this true?
    I am looking to run teh 12v motors at either 12 or 14.4v and i am wondering what kinda size wheels i would need for roughly 10mph
    Regards
    Ian
    Bosch 35watt Motors
    we run G3 currently on 14.4v and its fast and powerfull enough. We are upgrading to 24v when we get the brass gears, dont run at 24v without getting the brass gears, also make sure they are kept well cool.
    Cant remeber what size the wheels are, only about 50mm.
      Bosch 35watt Motors
      How much are these 35watt motors each?
        Bosch 35watt Motors
        Brand new about £55 each.
        From a fellow roboteer - not sure on the price. but under £35.
        Ian - go on what Alan just said, up to 14.4v is a decent speed and power on the normal plastic gears, then if you want, use 24v on a brass gear, long as ther kept well cool.
        But saying that- DTK has still hmm lets say damaged a few brass gears running on 24v still. But oh well - things happen.
        Mr Stu
          Bosch 35watt Motors
          I think Stu means me !.
          There 25 quid a pair when ive got some,
          which i havent at the moment.
          They do 700rpm on 12v and double that on 24v
          so a 120mm dia wheel would give 10 mph @ 12v
          or 60mm dia @24v
          GORD
            Bosch 35watt Motors
            Have anyone got some second hand ones they are willing to sell? I can afford £15 maybe £20.
            Thanks in Advance
            Aaron
              Bosch 35watt Motors
              Gordon, just re-read your post, £25 for a pair sounds good, do you happen to have a pair by any chance
                Bosch 35watt Motors
                Okay, not only still chasing a pair of these motors, but also wondering if anyone has gone to the extent of drawing a set of these motors up in Rhino 3D?
                £30 for a pair? Anyone :sad:
                  Bosch 35watt Motors
                  Hi Aaron,I dont have any at the moment ,but i do have a autocad drawing somewhere ill try to get it up online.
                  GORD
                    Bosch 35watt Motors
                    Ok you should find the Drawing here its a .DWG file
                    http:http://www.twnly-grdn.supanet.com/Std-bosch-35w.dwgwww.twnly-grdn.supanet.com/Std-bosch-35w.dwg
                    GORD
                      Bosch 35watt Motors
                      What version of AutoCAD did you use to draw that in? I tried to open it with AutoCAD R14 and it told me it was an incompatible version.
                        Bosch 35watt Motors
                        Aaron i use 2002 lite
                        GORD
                          Bosch 35watt Motors
                          mmm, Ive used AutoCAD 2001 Lite, is there a option to save it as an older AutoCAD version?
                          Still interested in the motors if anyone can help!
                            Bosch 35watt Motors
                            Aaron ive resaved the file in r14,so have another go.
                            GORD
                              Bosch 35watt Motors
                              Im Going to be putting an order in for some brass gears for the 35ws. We tried this before but when it came to putting order in alot seem to drop out. Post if you want some then i will get a price, ill find the price out next saturday, so will need to know before then.
                              Cheers,
                              Dave
