Thin Hardox
  • Thin Hardox
    hi people, i'm thinking of getting a sheet of hardox and surface grinding to 2mm thick if anyone is intrested in some also??
    i can do 1m by 1m sheets at a time on the surface grinder
    Re: Thin Hardox
    i might be interested in buying hardox un grinded. what thickness is the hardox your getting starting at?
      Re: Thin Hardox
      4mm
        Re: Thin Hardox
        how much for a 1m square sheet of that ?
          Re: Thin Hardox
          how much would you want for a 1m by 1m sheet mate??
            Re: Thin Hardox
            There is a wear plate version of docol that comes in 2mm so you don't waste material.
