setting up spectrum radio gear
  • setting up spectrum radio gear
    hello im having problems with my radio gear, I have tried the binding as stated in the manual but when i turn the robot on before the romote the wheel spin like mad, can anyone give me some pointers?
    Re: setting up spectrum radio gear
    erm,
    are you using a gyro? mabye you've got it plugged into the wrong channel- it needs to plugin into the stearing channel other wise that would cause a robot to spin uncontrollably i think.
    or your trims just need adjusting on the transmitter
    or, when you bind make sure you sticks on the transmitter are all in the neutral position mabye?
    one of those are what i'd think the problem is, hope thats been of some help
