Linear Actuators
  • Linear Actuators
    Hi
    I'm looking for a linear actuator to use for a lifting mechanism. I have looked everywhere and I can't find any. Ebay only seems to have really big ones. I only need it to extend around 6cm, with enough force to lift a featherweight bot. Does anybody know where I can get one from?
    Thanks
    Re: Linear Actuators
    Build you're own this link will help you: viewtopic.php?f=111&t=3440&start=15
      hi there
      i have a small linear actuator that will easily lift a fw and it extends about 85mm but this can be shortened to suit
      if your interested post here or pm me
      alex
        Originally posted by psycho_fling
        hi there
        alex
        Hi Alex,
        Whats the retracted lenth of the actuator.
        OR any links to spec's.
        Cheers,
        ROB....
          dimensions
          180mm long when retracted (including fixing points)
          40mm wide
          75mm tall
          arm travel of about 85mm
          alex
            Thanks for the replies. That actuator is a little too big to fit in my robot unfortunately, but thanks anyway.
            I will probably try building one based on the info from that link.
            Thanks!
