Is this too heavy?
  • Is this too heavy?
    Hi guys
    I'm a total newbie and i would like to know if i could fit a pneumatic flipper robot with spikes on the back into feather weight
    Re: Is this too heavy?
    Can't see why not, my featherweight in the making's a pneumatic flipper with spikes at the front
      Ok thanks. i just don't want to build it and find it's too heavy
      Sorry, more noob questions.
      What is a speed controller?
      Why do i need it?
      Where can i get one?
        Why do i need it?
        A speed controller is an electronic unit which basically switches your motors on/off/reverse and controls how fast they run depending on inputs from your radio receiver and therefore from your controller. You need it because your robot would just sit there without it. You can get one (you'll need two - one for each side of your robot - or a dual channel one) from all kinds of robot suppliers - electronize are okay as a basic cheap kind of thing. else you want to look at a scorpion xxl or sabertooth. Those are the main types used by UK feathers.
        Electronize - http://www.electronize.co.uk - or i am selling two. You'll want two 15 amp ones for two drills (FR15HVRs), or two 30 amp (FR30HXs) for two drills a side for four wheel drive.
        Sabertooth (you'll want the 2x25 for 2 drills, won't really like anything more than that) - http://www.technobotsonline.com
        Scorpion - http://www.robotpower.com/catalog/ - have to order them from the US.
          Cool, thanks a lot
            Yes it's me again with more noob questions.
            Do spikes on the back really do anything, or would i be better using something else, if so, what?
              Spikes with 13.6kg behind them won't do more than scratch anything stronger than a Dave Lawrie creation (and probably not even then) - your best bet is to use the weight to improve your flipper, structure, drive, or armour.
                Slightly harsh on dave lawrie there Nick, His latest one was quite sturdy.
                Spikes are only really much good if you can get something resting on them. On Satanix, I tend to ram people into walls and they go over the robot and onto the spikes, so I can ram them again and hopefully dent/bend the base panel. I have caused one noticeable bit of damage; I put a hole into Pug's battery pack at Edinburgh when it was hanging loose from the robot.
                  Right, i will leave out the spikes and maybe make a really good flipper
                  Lol, i have yet more noob questions
                  What type controller should i get?
                  2.4ghz
                  40mhz digital
                  they are the only ones i can remember
                    2.4ghz is more reliable and from next year 40mhz won't be a permitted frequency for featherweights. The price of 2.4 has come right down now so they are a much better prospect.
                      cool, i will get one of those, and once again, thanks for the help
                        Do any of you guys know any weapons that are reasonably cheap to make and are very good because A) i have just lost a sizeable chunk out of my budget and B) flippers are boring, everyone has them
                          A wedge is pretty effective but if you want something active a drill/windscreen wiper motor powered lifter might be the way to go.
                            cool, thanks a lot
                            Are buzzsaws and spinning discs any good?
                              u could build 1 but i wouldn't because most contests will not let u fight
