robot
  • #76
    Re: robot
    where about in breadfield alex?
    • #77
      Re: robot
      can't remember, near the caterey?
      • #78
        Re: robot
        OK next time I see you I'll ask you where it is.
        • #79
          Re: robot
          http://maps.google.co.uk/maps?f=q&so...47198&t=h&z=10
          The magic of the internet
          • #80
            Re: robot
            I've got all the bits for the lifter (except the esc) but how would I control the motor? How would i wire it up?
            My dad says that we use microswitches and make a bang-bang speed controller and at either end of the threaded rod
            we have a limit switch that when the nut reaches the extent of its travel the motor cuts out to stop the motor ripping the lifter mechanism and itself apart.
            We need to be able to control it so when the lifter reaches the extent of its travel the motor cut outs.
            • #81
              Re: robot
              http://homepages.which.net/~paul.hil...ingTravel.html
              If you can get some double pole double throw relays (aka double pole change over) and some microswitches that will do the trick.
              Technobots and Maplin both do some that should be suitable.
              • #82
                Re: robot
                technobots are cheaper i think
                • #83
                  Re: robot
                  what is the overall size of the bot?
                  from blue wheel to blue wheel, the length (including and not including the lifter)
                  and finally the height from the ground to the top of the bot?
                  • #84
                    Re: robot
                    width : (side to side) 470mm
                    length : (lifter to back) 520mm
                    length : (bulkhead to back) 350mm
                    height of chasis : 68mm
                    height of robot : 96mm
