just a quick question wot do you think of the technobots feather gold motors 12v 150w ?? are they any good for a featherweight robot? or is it better just sticking with drill motors. was thinking of using them but not totaly sure if ther any good??? :shock:
Re: technobots feather gold motors
I haven't used them personally but they've been used in a lot of featherweights before including DB5, Cutlet, Cyberon and 4 4 Toon so I'd say they're worth a go (if you can build your own chain/belt/gear reduction, one thing they lack compared to drill motors is inbuild gearing)
In DB5 i use the 24V version that is no longer avaliable, im down to my last 2 now so when they go I will need a replacement. Am currently thinking of the boschs that Alan uses in Alpha. The experience from others is that the 12V version is ok, but don't over volt them as they tend not to like it as much as some motors.
well thanks for the help.
i might give them a try just to see how they are although will keep a look out see if thers any thing else about. dont really fancy using drill motors. cant bring my self to ruin a perfectly working drill
but again thanks for the help
You can buy just the motor and gearbox combo from a drill from http://web.me.com/robochallenge/Robo_Ch ... nical.htmlOriginally posted by G-DogG187dont really fancy using drill motors. cant bring my self to ruin a perfectly working drill
(bottom item)
That way, the ruining of a perfectly working drill has already been done for you
well ,i only use my teeth as toolsGive it a few months and you'll have a hard time keeping your tools in one piece!
but no i got the tool bit covered so wont have to worry bout that for a while but i guess ill find that out. fun and games
thanks for the link had a look, will probebly buy wheels from robo challenge. but have decided to use drill motors ,got a couple of 12v drills for well cheap so am gona use them but thanks for the help anyway, the reason i wasnt wanting to use the ones i already had was because they where dewalt drills and not realy wating to put them into my fist robot. seeing as its pupusly gona have thin armour for all the spinnersYou can buy just the motor and gearbox combo from a drill from http://web.me.com/robochallenge/Robo_Ch ... nical.html
(bottom item)
just one more question. this is the bit im not sure about coz my physics is crap, but for speed controllers i was wondering if you had any advice
Speed controllers isn't really that much of a physics area :P all you need to know is a few simple amp ratings and what other people use.
The only two bits of information you really need to know are:
- the stall current of the motors you intend on using (for drill motors it can vary, but in any case you're unlikely to stall the motors unless you manage to break the gearboxes in combat as usually the wheels will slip first...I've heard 20 to 30 amps quoted as a ballpark figure for 12 to 18 volt drill motors run at their rated voltages, so that can be used for now)
- the maximum current that the speed controller you're looking at can handle. It's worth noting here that radio controlled car speed controllers - usually recognised by a massive coloured heatsink and an 'edgy' name - tend to use the raw specification of the FETs (the thingymajigs that do the speed controlling) for this number and so you get quite weedy devices claiming to provide control over 180 or 200 amp currents - they won't, and it's usualy good to avoid R/C car speedos entirely for this and other reasons.
Ideally you want the second number to be higher than the first. In practice you are unlikely to see the stall current, unless you break the motor, for more than a fraction of a second, so you can *probably* get away with a 50A maximum controller for a motor that draws 60A at stall. (bear in mind that I've never fought with anything more than antweights so yu may want to check this with someone with wider experience, I'm not an engineer :P)
The best gauge of what works though is what other people use
For drill motors, the following have all been used:
- Sabertooth 2x25 (this is a dual controller that combines control of two motors, and control mixing, in one unit - this only handles 45A peak though, and if run with overvolted motors has been known to cut out under sudden acceleration due to the high amp draw)
- Scorpion XL and XXL (also dual controllers, not heard of any problems with these)
- IBC (also a dual controller, which has another channel from which a weapon relay can be activated)
- Electronize 15A and 30A (these are single channel controllers, so you need two - if you're proficient with electronics though you can add external relays to improve the current handling, Jamie will know more than me about this as he's done it quite often)
- RobotPower Sidewinder (also a dual controller, handles 80A continuously and is really overkill for featherweights)
- RS80E (I think that's what it's called - Alex Marler used one of these, ask him for more information but I believe it's also a dual controller)
- 'blue boat controllers' (these are single channel but seem to work well, aside from that I know nothing about them, sorry :P)
Hope that all helps, other people who know more than me will be able to correct or add to this ramble :P
with most electric speed controllers (ESCs) they burn out and die if you put the polarity the rong way round
, try not to do this as ESCs are expensive. I wouldn't by duel ESCs because If you burn out 1 side you destroy the whole thing, so I would get 2 seperate ESCs.
I use these's
http://www.technobotsonline.com/syren-2 ... oller.html
because they are programmable and have a peak current rating of 45A which are achievable for a few seconds.
I have used the xl with the Rick Maas Mod great little thing
also used electronize tbh hated them, so hard to get the run straight blah blah and quite pricey
sabertooth yeh they are great but will cut if you flick to go full throttle from rest but ok
@ Joey nearly got it its an RS80D but they seem to have been discontinued and i got it for speed 900s over kill for drills and possibly for fw
I don't agree here if you plan well enough this shouldn't happen and they can be repairedwith most electric speed controllers (ESCs) they burn out and die if you put the polarity the rong way round , try not to do this as ESCs are expensive. I wouldn't by duel ESCs because If you burn out 1 side you destroy the whole thing, so I would get 2 seperate ESCs.
Dual controllers have bee widely used and if used properly then your ok and imo you get better results
go with a sabertooth 25a id say
alex
