new robot
  • new robot
    Hi, I'm new to this robot hobby and I want to build my own robot I'm into electronics and DIY
    this is possibly what I'm going to get...
    2x 12v cheap drills from screwfix
    wheels from robo chalenge
    these speedos: http://www.wheelspinmodels.co.uk/car/it ... mit__2869/
    8mm HDPE for armour and metal framework
    pneumatics for the flipper
    and a battle switch
    can anyone give me advice on these things im going to get?
    For RC I have a spektrum DX5E http://www.horizonhobby.co.uk/aeroonlin ... 6dx5e.html
    or I can get another 2.4ghz from http://www.giantcod.co.uk/gianitcod-24g ... 03779.html
    the design is a simple ram bot with a flipper on the front of it.
    PDF attatched red-motors, blue-wheels, black lines-plastic
    Re: new robot
    Those speedos will be useless, the reason is that RC car ones generally can handle rather less current than they're rated for and don't reverse at the same speed they go forward. This means your robot won't turn well.
    I'd recommend something like a pair of electronizes, a sabertooth, a scorpion xxl, or something like that which is more intended for robots.
      Re: new robot
      You will want to get motor mounts from robo challenge too. Infact it might be worth getting wheels drill motors and the motor mounts from them, Unless your wanting to use the drill batts in your robot, But id advise getting a couple of nicad or nimh packs. Your going to need a charger and possibly a powersupply for the charger unless the charger comes with the 230-240v mains plug already. You can probably get everything you need minus some parts for your pneumatics system from robo challenge and technobots. Might aswell get the Sabertooth Dual 25A speed controller if you order bits from technobots as they sell them. And the DX5e is fine.
      Basics:
      Wheels - Robo Challenge
      Motors - Robo Challenge - Screwfix - Argos
      Motor Mounts - Robo Challenge
      Wire and Connectors - Robo Challenge - Technobots
      Link - Robo Challenge - make your own
      Speed Controller - Technobots
      Batts - Ebay - Vapextech
      Charger (maybe a supply too) - Technobots - Ebay
      LED - Technobots - Ebay - Maplins
      And its worth putting an ad in the wanted section for some bits too. You might get some good deals.
      You can shop around and get things slightly cheaper but I prefer to get as much from one place as possible, plus say you was getting afew bits from one place and find another place with the same thing a little cheaper it will probably end up costing the same because you have to pay another postage cost or whatever.
      Really all robochallenge have to do is start stocking speedos and leds and they will be close to providing a full kit to start a robot. If they do start doing speedos they should be a uk distributor of the Robot Power speedos or something, Does anyone sell the Robot Power ones over here anymore? I prefer them over the Dimension engineering ones.
      I wouldnt go for a flipper straight away unless you have a bit of experience with pneumatics.
      wha? ehhhh bed time I think, Falling asleep typing.
        Re: new robot
        thanks for your advice i will probally get the 30a electronize speedos:http://www.electronize.co.uk/model_e...ics_frames.htm
        or i can get these syren ones http://www.technobotsonline.com/syren-2 ... oller.html
        I can do pneumatics and ill get the motor mounts
        i do have a spare charger for the drills
        thanks
          Re: new robot
          if its a normal drill charger you will be waiting a long time between charges
          a good fast charger is best
            Re: new robot
            i could buy a fast charger or i can use my car charger that chrges at 2.5 amps
              Re: new robot
              hi ben i'm wondering about the pneumatics because you don't have a masive amount of experince and you haven't been to an event before.
                Re: new robot
                alex look at my other topics and i know about pneumatics
                  Re: new robot
                  yes you have got lots of advice but it would still be a very hard to make
                    Re: new robot
                    Ok, I've looked around for ESC's and I am intrested in the Sabertooth 25 Dual 25A Motor Driver
                    from http://www.robotmarketplace.com/product ... 25-RC.html
                    can anyone give me advice and the good and bad things about it.
                    Thanks
                      Re: new robot
                      Sabertooth 25 Dual 25A Motor Driver is nice,
                      I planning to buy but quite expensive :sad: ...
                      So I am thinking of using relay which quite cheap...
                      Can I know instead of using ESC, what if I use relay to create the H-Bridge? will it create a lot of problem when control the motor?
                        Re: new robot
                        Depends how fast your robot is. Its quite impossible to drive faster robot like my miniroll with on-off speed controllers. But im cheap, so they work for me!
                          Re: new robot
                          www.riobotz.com.br/en/tutorial.html
                            Re: new robot
                            Oii Tony, this is tantamount to spamming
                            Seriously though, that tutorial is a great read and a great help
                              Re: new robot
                              That is a great book and it tells me things on how to make my first robot.
                              Thanks Tony
