Fellow roboteers,
After 5 years doing spinners and some wedges in Brazil, I decided, since moving to the UK, to do a pneumatic featherweight.
Almost all components are defined and some were already bought, but I am heaving trouble defining the adaptors and fittings. What do people normally use for full pressure? I thought about using hydraulic adaptors from Burnett & Hillman rated for 350bar on a Aluminium manifold.
The system will be a custom, 65mm bore ram, with integrated valve. So the fittings for the Buffer tank will be 5/8~3/4 BSPP and for the main cylinder, to avoid icing, I thought about G1/8 or 1/4.
What are the experienced builders opinions on these matters?
Also I would like to take this opportunity to thank Woody for his resourceful website and all the forum members for the shared knowledge.
Regards,
Eduardo
Regards,
Eduardo
), also it will be shock mounted. I will probably use those plastic hoses from the buffer to the dump valve, just need to find a place to put it! LOL! The costume is a custom made Freakazoid! My brothers always said that Dexter resembled me, so when the opportunity came, Freakazoid was reborn. Probably in July I will compete in Brazil dressed as such, the organizers normally wear costumes.
