Hello, I am considering making a 4WD for my second robot. I am a bit confused about this though. Do I need 4-channel radio gear, or do I just run 2 motors through 1 speedo?
4WD
Re: 4WD
Welcome to the forum first
As a general rule anything that's designed for remote control cars and is rated at aburdly high levels should be avoided, they'll just blow up. The Electronize controllers have a good reputation although you need at least two of them (one per side), while the Sabertooth 2x25A controls both sides in one unit and is quite good in my experience (I wouldn't use it on anything more powerful than drill motors though)
Everyone has their own recommendation though, based on their own experience, so it's best to ask
Re: 4WD
Thanks Joey.
Can anybody who had particularly good experiences with a 4WD feather please reccomend me a speedo?
Edit: While I'm at it, I've got two more questions:
1) Can anybody recomend a 2-channel radio system?
2) Do feathers need gearboxes?
Re: 4WD
most of us now use a radio system called spektrum these radios have some really good features and are as cheap as some fm stuff
they only come in a minimum of 3 channels, but those are pricey there are some 5 channel ones cheaper (would you believe)
you will need some kind of reduction gearbox on any motor
if you just want to practice and see if this is for you gor the cheaper option of 4 drill motors these have gear boxes attached you see
decide upon your motors then the contrller to go with them
alex
Re: 4WD
having good 4wd experiance id say, for your first bot, make a nice rectangular base, then get 4 drills from argos (£10 each or so) and mount themto your base. get some blue wheels from james or grant cooper and they just screw onto the drill shaft, then wire the two left motors up to each other, you should have two wires left over, do the same to the other side, buy a speed controller, id recomend tom wilkinsons speed controllers as they are very good and quite cheap, he isnt a big brand though so if he dosent have what you want the electronize speedos ( a different word for speedo is esc btw) ut you wil need 2, wire the wires from the drills into their respective esc/s (one es for each drill if its electronize, one esc for both if its a dual esc) and then plug the other wires coming from te esc into the reiciever. there should be a battery slot coming from the esc, plug your battery into there, well thats my area of knowledge :P ask around for other tips, we dont bite....mostly :P
Re: 4WD
yes he is
he and his brother james cooper run the full combat featherweight show robo challenge
james:
memberlist.php?mode=viewprofile&u=881
grant:
<a class=postlink-local href=http://www.fightingrobots.co.uk/foru...r /> <br /> oh
Re: 4WD
You asked:
1) Would you reccomend the mtronics eco 27 speed controllers?
No. With a 4 wheel drive machine you would need 4 of them, one per motor, because they can't handle much current. Even with 4 you might well overload them and for the price of 4 you could get more capable speed controllers. Also, they only go up to 12 volts so you can't over volt your motors which is a good way of getting extra speed and power. I used them once on a 2WD 8 kg feather and they worked for a while but were just not up to it.
2) Where can I buy a safety link + LED?
You can get a wide choice of LED's at Maplin. You can buy a link from Technobots or you can make one yourself. For feather links I use a loop of wire terminated in male bullet connectors with female ones inside the robot. Cost is about 10p if you have a pack of each kind on hand and you should because they are very useful for joining up things inside your bot.
Caome to an event and have a look at people's links - there are lots of ways to do it. I've sen one made out of a 13 amp mains plug.
Re: 4WD
yeh the spektrum can be used with many different things including drill motors
http://robotbirds.com/catalog/product_i ... ts_id=1540
thats a dx6 with 6 channels i have 2 they are great and have decreased in price, trust me you will be glad of more channels you can also charge this one with the a wall charger and it has a good build qulaity feel
hope this helps
alex
