Full Pressure Buffer Tanks
  • Full Pressure Buffer Tanks
    Would a piece of Aluminium Tube such as this with the ends welded up be suitable for a Full pressure buffer tank for a featherweight??
    Thanks
    Re: Full Pressure Buffer Tanks
    Nope.
    I'd strongly suggest that you use an existing component rated for the required pressure, or get something designed and fabricated by someone with experience doing pressure vessels. As I'm sure you know (I'm guessing a few of your robots are full pressure?), 750psi gas has the potential to be extremely dangerous.
    Incidentally, the design you suggested (I'm assuming the end heads to be flat from you just describing the ends being welded up, they are also assumed to be the same thickness as the tubing) has very little margin for safety whatsoever (750psi will be ~70% of burst pressure according to some quick scribblings) and wouldn't be usable.
      Few of the aussie flipper guys use 12oz or 20oz paintball tanks for buffers.
        Will,
        the build rules on this sort of thing are quite strict, If you make it yourself it will need independent inspection and certification before you can use it.
        Build rules, section 8 refers....
        8.7.1
        Custom made components, or parts operating above the suppliers maximum working
        pressure, must be independently tested and certified at 120% of the maximum
        system pressure available at that point.
        Geoff.
          Thanks for your help,
          I have a 9oz paintball bottle and a sodastream bottle (they are pretty much the same size), In that case I will just use both of them in the system.
          We got the idea from looking at both of the Beauty's last weekend which seem to have a similar set up for their buffer tanks.
