Best way to......
  • Best way to......
    best way to secure a Sabertooth esc to the chassis
    Just bolt it down with the nuts and bolts supplied or is there a safer way not to get it damaged with the shocks it will get.
    Thanks,
    ROB....
    Re: Best way to......
    On Dinah we used longer bolts than was supplied with extra nuts to act as pillars thus creating a gap between the polycarb and the controller.
    Hope this helps
    Ian
      I would use anti-vibration mounts either direct to the speedo or if mounted in a box, mount the box to the chassis with the anti-vibration mounts.
        As Paul said, its best to give them abit of spring..
        360s is mounted on a piece of titanium that can flex, then bolted to that through the mounting holes with rubber mounts underneath (you can get a pack of 50 for a few pounds from maplin) Never had a problem with mine.
        Id suggest you put abit of silicone glue or somthing across were the R/X cables come out of the board, as over time they will get pulled and the insulation with pull away from the wire and get close to shorting out, Just makes it abit safer.
          i made a quick simple hdpe platform that mine sits on. i also use hdpe as the mounts, the clusterbots have them in and the have been thrown really high (only weight 6.8kg each) and the speedo's survived fine.
