im finialising plans for a feather spinner but im not sure about the best way to tension the drive belt for the weapon.
with my current robots i use belts for the drive and i tension those using a motor bracket that slides to either loosen or tension the belt and then i would then tighten the bolts on the motor bracket to hold it in place, would this work for a drive belt for a weapon???
althought i know it would in theory work (as it does in my current robots), i didn't no whether it would be best to have a spring loaded tensioning system to allow the belt to mabye give a bit if the spinning weapon was suddenly stopped.
any one got any advice?
thanks for now
thanks for now
