do you get the same force whether its opening or closing?
Electric actuator question.
 i found a actuator that has the following spec.
 Load capacity: 2500N/ static load: 4500N
 basically on my hw if the robot is flipped on its arse end lol, i wanted to use a actuator to tip it back onto its wheels. as weight is a problem and tried different methods the easiest way i found to solve it is with a actuator.
 i want to mount it quite high in the robot to push a rod to tip it back over. would these specs be sufficent. thanks
 The load capacity is the movement capacity, that actuator is ment to move a load of 254 kg directly on the spindle.
 The static load is 458kg, meaning the mechanical bits can hold at least a weight of 458 kg before failing.
 Leverage can change the numbers of course.
