Aluminium rod
  • Aluminium rod
    will a 12mm diamter rod of aluminium be strong enoguh to use for a selfrighter device ona featehr weight (90mm in length)
    thanks alex
    Aluminium rod
    there is a good chance that it will bend
      Aluminium rod
      im guessing ti then for weight to strength ratio???
        Aluminium rod
        whoops sorry i misread your original post, thought you said 900mm. A 90mm long bar should be fine for a featherweight
          Aluminium rod
          Is that a typo? if 90mm it wont bend, if 900mm it would flex alot but should get the robot over fine.
            Aluminium rod
            no 90mm thanks guys
