Hi, What radio gear do you all use and how do you have it set up? At the moment im using 40mhz Futaba skysport 6. i have taken appart a second futaba skysport 6 to modify this one so both sticks are spring return, i know you can get the spring return kit but it was about 11pm saturday night after the Huddersfield event and i wanted spring return for the sunday event so i could use it tank style without one stick being on a ratchet. That is just for my bot Hooligan so im only using 2 channels. Now for Savage i will need to use a 3rd channel for the flipper. How do you guys find it easiest to fire the flippers or axes on your robots? Im thinking of getting a DX5e or something similar so im on 2.4GHz.
Cheers
Cheers
