Featherweight Discs
  • Featherweight Discs
    So true Rob!
    I€™m considering building a featherweight using an EV warrior on a disc...the disc will probably weigh about 2kg, this wont be around for some while, However, so some rules may come up between now and the 3months in the future when I start work. But what thickness would people suggest I make the bulkheads of the robot supporting the disc from...I was thinking 8mm Ali...As 10mm is OTT? Any thoughts?
    Regards
    Dave moulds
    Team Turbine/PLF
      No Dave, 10mm aluminium is NOT OTT for supporting bulkheads. All of the bulkheads in Storm Vortex were 10mm 2014T aluminium
      Ed
        Tim - sorry, couldnt let that pass. Youve persuaded me, Im going to *have* to build a robot just so that I can teach you to play winks in the pits between fights. (People have been hospitalised, you know.)
        Andrew Garrard
        Publicity officer to the English Tiddlywinks Association
        Winking World editor
        Webmaster of http://www.cutwc.orgwww.cutwc.org
          I agree with Ed- tho you can pocket it loosing very very little strength, but reducing the weight alot. Just be careful about how much/where u pocket.
            I agree with Rob that we need some more none-effective weapons, that the crowd will still love. I was toying around with an axe-bot but gave the idea up as It wouldnt stand a chance with any of the new bots.
            As there are so many featherweights about I think we should set different leagues for different robots (e.g The under 15s could go in one group and the rest in the other) This would give a chance for the new bot builders out there to fight someone their own size... My personal excuse for building not so good bots so far is one word... MONEY
            Seeing as Im still only 12 I aint got much of it :sad: (at least now Ive got two sponsors I can promise the next bot to be better)
            Anyway you big guys should still make OTT spinners, fight each other and start to hear the ohhhs, and ahhhs from the crowd...
            Cheers, Ewan
            http://www.micro-maul.co.ukhttp://www.micro-maul.co.uk
              Well Im glad to see people are looking at having a sensible spinner rather then OTT spinners. Even though our tri rotor going back onto Annihilation is 4kg, it is built fairly damn sturdy. we have uses 20mm box section for the hammer supports and we have 5mm solidbox between the hammers to stop them from bending the arms. We have the whole weapon mounted on a 22mm ride on mower bearing. There is a picture of the rotor on Annihilation back before it got the paint job and the weapon change on the http://www.featherweights.orgwww.featherweights.org database for those who wish to have a looksy
                hey, forget what I said earler.......
                new spinner is 10kg at estimated 1500rpm 450mm diameter......
                mwahhhaahhaaaa
                (not as impressive as it sounds actually, youll see when it next appears.)
                  Mr. Baker- If youre trying to make what I think youre trying to make- its extremely difficult to get something so light to translate properly with only a 2kg ****** (just so its not too spoilt :-) a 3kg is much better. Having said all that, theyre still exceptionally difficult to make! The one Im working on (kinda a 2 year project due to really slow rate of income) is going to have translation speed control, via means of a cunning little variable eccentricity cam my friend came up with. We have the design sitting on Pro Engineer, a few parts, little money to do it, and trying to find a friendly firm for the large number of CNC parts it requires! Incidentally, the G Forces on the rim of ours (similar speed) are about 850G- so a kilo of batts suddenly weighs 850kg as far as the chassis is concerned! Its really quite a scary prospect!! Also, our little MDF mockup which we built to test translation, and only ran about 180rpm, FLEW when we caught the edge of a workbench. Just imagine what it would be like at 1500rpm. I am genuinely worried about this particular type of robot- they really are quite astoundingly dangerous, and Ive heard it on the grape-vine that other slightly better funded builders (no prizes for guessing who) have similar plans for a heavyweight version. If thats not what youre building, my appologies! Its just the figures youve quoted there would suggest it might be (unless its a walker, of course, in which case Ive just made myself sound very silly )
                  Regards
                  Ed
                  *Insert Something impressive sounding written in red*
                    Yep, as soon as someone makes an effective featherweight walker (no offence to mammoth) theyll be able to stick a 12kg disc on it...
                    If only I had a few more sponsors...
                      Damn! I though I was the only one crazy enough to design Translational Spinners! Ill have to get cracking then!
                        @Ewan
                        Age In my opinion should not be the restriction. There are some people that at 12 will have the cash and the facalities to make very good robots. It could be much fairer to go by money than age.
                        Regards
                        Ian
                          I agree, but age is mostly a way of judging income.
                          It would be very hard to judge someone by how much money they have.
                          Cheers, Ewan
                            Not by how much they have but by how much money they have spent on the robot. By that i mean they may have spent 5pounds and got loads of sponsership but anything that was sponsered has to be taken as they paid for it.
                            Regards
                            Ian Mc Donald
                              Again I feel that would be rather hard to judge, a roboteer could quite easily say they got something from a scrapyard when it cost 200.00, youd need to make a huge table with details of how much a certain item costs which is now gettig rather ridiculous...
                              (and no, I dont get THAT much sponsorship )
                                well have to wait and see about mine, but the well off team you mention abandoned its plans if we are talking about the same thing.
                                Well have to wait til it happens then panic
