Hi guys
Basically, Ive put my robot back together, and for some reason Im having a re-occourance of a problem from Colchester, where the motors switch direction when I press forward on the TX (I press forward and they go forward for a second, then turn backwards and then forwards, then back again, without me changing the directions on the TX). Since it worked fine at Derby and I have since gained a new and more secure areial, Im convinced its not the RX, but the speedo, but I cannot understand why.
Whats just as weird is that when I do a turning movement (left and right) there is no problem, the motors turn the correct what and stay that way.
Any suggestions ?
Any suggestions ?
