Speed 900-gear ratio
  • Speed 900-gear ratio
    hi all
    for my crusher i now want to use 2x speed 900s, running on either a 25a abertooth or a scorpion xl/xxl-all running off 21v
    however i would like to know a suitable gear ratio to use, in order to get good speed and high pushing power
    any info/ help welcome
    thanks alex
    Depends on wheel size.
    Let us take a 80mm Colson as the wheel.
    @21V the Speed 900 runs 11550 rpm.
    Aimed for speed is 20km/h
    gives me a 9 or 10 to 1 gear ratio.
    Youll end up with a 2 stage gearbox.
    With a 8-1 gear ratio youll get about 24km/h
      i was looking at using either 100mm wheels or 75mm ones
        Simple calculation then.
        1-10 ratio on a 100mm wheel gives 21 km/h
        1-8 ratio on a 75 mm wheel gives 16 km/h
          so i can use the 100mm wheels? matt said they would be to big
          by the 1-10 ration i would need the gear on the motor shaft to have 10times less notches on correct?
          such as 5 and 50?
          thanks alex
            Aboutish.
            But I doubt you can find a 5 teeth gear to fit on a 6mm axle.
              just go for the smallest T gear u can find and then the biggest size which is nearest the size off wheel if u want a 1 stage reduction
              then guess the ratio and speed
                is this the right sort of layout?
                the page should work (i hope)
                http://psychoflingteam.piczo.com/robotimprovements?preview=y&cr=5http://psychoflingteam.piczo.com/rob...preview=y&cr=5
                also where do i buy the gears from?
                thanks alex
                  Your Example is a single stage reduction, with 21V that will be really fast. We use a single stage with speed 900s, but on 12V and even then if we dont put our armour on it pulls a wheelie every time.
                  http://www.computerclub.nl/uploads/msrconcept.jpghttp://www.computerclub.nl/uploads/msrconcept.jpg
                  You can find gears in several locations, one of them is RS Components.
                  http://uk.rs-online.com/web/http://uk.rs-online.com/web/
                    We have driven the Hannibalitos with dual rate, so the voltage supplied to the motors was less than 6V, and still they are fast and fast accelerating.
                      I get my gears from technobots but if they dont have what i am after then HPC gears always does. Bit more pricey but the service is very good and you can get them to carry out various machining operations (at cost) on your gears.
                        ok so i just had the size of gears the wrong way around?
                          No i think it was right. Small gear on the motor, large gear on the wheel. it is a reduction, not an accelation you need.
                            hi leo could you reply to the email on my profile with your reply to my pm i sent to you?
                            thanks alex
                              just had a thought probably wont be suitable but, are there any tools which contain suitable gears which could be salvaged?
