A few questions
  • A few questions
    hi all
    im looking for my crusher instead of using 2x electronize controllers for the drive, a dual controller. i have been looking at the sabertooth 10a and to me seems like what i need, any advice? i know everyone will have different preferences but i want something that will do the job, elimate going of on a tangent instead of stright line, and some thing which is cheap.
    i want to use this as an introduction into the dual controller area of things
    next question....
    also for my crusher i want to use 3x 7.2v nicad packs, but i ws wondering if it is possible instead of 3x 6 cell packs, 2x 9 cell packs?
    and if anyone who is able to do this? as im not the best with batteries
    thanks alex
    A few questions
    flow and 360 uses a 10a sabertooth for bosch 35s they really nice, they will probly work fine with drills aswell, but i would recomend going for a 25a sabtertooth for yourself becuase you can use it other robots later not worrying bout it ( aslong you dont to astros or similar)
      A few questions
      You can use two 9 cell packs or indeed one 18 cell pack.... the limiting factor is your chargers ability to charge them.
        A few questions
        used both, and both work fine with drills, shame i just sold one of them!
          A few questions
          yeh i know adrian i did want it but was to late
          ill have a look at the 25a version look at the prices etc
          does anyone on the forum change battery pack arrangements around?
          thanks alex
            A few questions
            can i just ask what is the difference in terms of parts involved, between the 25a and 10a controller?
            thanks alex
              A few questions
              Both controllers are the same size, use the same layout for contacts, same fixing hole centres, apart from current rating are externally identical
