Hi
I just felt i had to start a topic about this. I have downloaded both videos from the website and all I can say is F**KING HELL
Its brilliant. That hawker flew and the selfrighting is comic.
But that leads me to a question. Why use Full Pressure? Surely a 16bar ram with a larger bore would have the same force and use less co2. Admittedly this may not be as fast but look at m2 it uses 100mm bore ram in a heavy. If you put a 100mm bore ram in a feather at 16bar it would knock people all over the place. I am going with 63mm bore 10bar which is think is loads for a thrower.
What do you guys think?
Is full pressure the way to go?
Will i be out of date with a 10bar ram and high flow rate?
Regards
Ian Mc DOnald
Regards
Ian Mc DOnald
