Wire up a linear to work both ways on a 2 way electronize sw
  • Wire up a linear to work both ways on a 2 way electronize sw
    hey,
    im trying to wire up a linear acuator up for both directions using a 2 way electronize rc switch and was wondering if anyone had a wiring diagram?? need it tonight if possible for my cousins christmas prezzy!!
    i need a 4 way switch dont i
      i am going to use an electronize switch for mine too. the RLA and RLD go to the motor, then i beleive the NO or NC goes to the micro switch then from the micro switch it goes to either neg or pos pwoer. same for othe microswicth
      or if the linear actour has limit switches you can just use a normal electronize which you would use for drive
      sorry its not perfect but not 100% sure myself
      hope you get it sorted!
