Hi All,
After Saturdays Roaming Robots event I have to say I was quite impressed with Cylon. It took quite a good hammering at times including being thrown out of the arena and just kept on going.
After taking it apart and seeing why it started veering off to the right, it turns out the friction drive only failed because of a grub screw falling out.
There are a few upgrades I have been considering. Some of which are no brainers and some of which are a wish list. Just after some advice on some of this, so ill start from the top and carry on from there.
1) The removable link becomes easily dislodged so i was looking to replace it with one of the red ones everyone else seems to use. Anyone know where to get them?
2) It doesnt self right if it lands on the back part of the robot. This is a bit of a problem with the basic shape of the robot. That said Im a bit reluctant to change the basic shape of the robot (it does look very good and I have to say Froggy has produced a bit of a work of art there!!) and dont quite know how to sort that out. I had some ideas about introducing some spikes at the back to stop it happening or some sort of clear plastic strip on the lifter.
3) It needs dropping at the front so its more likely to get underneath things. This seems simple enough. It currently has a 20mm roller balls underneath and i was thinking about replacing it with two 10mm roller balls. These seem a bit flimsy but interested in others experiences if any.
4) The friction drive is great for getting about the arena and surprisingly reliable when using the aluminium rollers. That said it really doesnt deliver a great deal of power which means it gets pushed about by anything on the arena floor. I have attached some photos of the mounting etc. and would appreciate some comments/opinions on how best to convert this to a geared system. There is limited space to introduce this. The wheels are 50mm diameter at the moment whith about 15mm spare space (diameter) and about 15mm depth if i want to introduce some different ones. I would prefer to keep the existing ones, but not fixed on that idea.
Anyway, any comments welcome. As I say Ive put some photos on line. You may have to cut and paste the links to your browser as it doesnt seem to be picking them up properly.
Andy
http://www.highstreetsearch.co.uk/cylon/03122007.jpghttp://www.highstreetsearch.co.uk/cylon/03122007.jpg
http://www.highstreetsearch.co.uk/cylon/03122007http://www.highstreetsearch.co.uk/cylon/03122007(001).jpg
http://www.highstreetsearch.co.uk/cylon/03122007http://www.highstreetsearch.co.uk/cylon/03122007(002).jpg
http://www.highstreetsearch.co.uk/cylon/03122007http://www.highstreetsearch.co.uk/cylon/03122007(003).jpg
http://www.highstreetsearch.co.uk/cylon/03122007http://www.highstreetsearch.co.uk/cylon/03122007(004).jpg
http://www.highstreetsearch.co.uk/cylon/03122007http://www.highstreetsearch.co.uk/cylon/03122007(005).jpg
http://www.highstreetsearch.co.uk/cylon/03122007http://www.highstreetsearch.co.uk/cylon/03122007(006).jpg
http://www.highstreetsearch.co.uk/cylon/03122007http://www.highstreetsearch.co.uk/cylon/03122007(007).jpg
Andy
