With 750 rpm drill the top speed was 30 mph at the top of the page is where i got it from. And then you even went on to suggest that youd run them at 1000rpm!!
Anyway, youll get cheap 9.6V drills for a tenner each. Woody posted a link with instrctions on how to modify them. Get the motor mounts and 75mm blue wheels from Robochallenge and overvolt them to 12V or 14.4V and youll have a pretty good drive system which is at the top end of what you can control properly.
The gearbox is slightly different to the cheaper cordless drills...but suitable if you wish to go the Makita route.
http://www.powertoolspares.com/makita_parts.php?ModelID=29528http://www.powertoolspares.com/makit...?ModelID=29528
Thanks for the warning. I actually have a set of 7 cm wheels (my Grandfather came down today), and we have decided on 2 drills, made four wheel drive by timing belts.
Looking to buy some drill motors for my first bot. Was just wondering if people had any experience with any of the following drills and to see if any of them worth getting
This one http://www.diy.com/diy/jsp/bq/nav/nav.jsp?action=detail&fh_secondid=9806513&fh_refth eme=promo_134841494%2cseeall%2c%2f%2fcatalog01%2fe n_GB%2fcategories%3Chttp://www.diy.com/diy/jsp/bq/nav/na...d=9806513&fh_r eftheme=promo_134841494%2cseeall%2c%2f%2fcatalog01 %2fen_GB%2fcategories%3C{10082}%2fcategories%3C{10 084}&fh_view_size=6&fh_sort_order=1&fh_sort_by=_pr ice_ rrp_min&fh_location=%2f%2fcatalog01%2fen_GB%2fcate gories%3C{10082}%2fcategories% 3C{10084}%2fcategories%3C{9181016}&fh_eds=%C3%9F&f h_refview=lister&ts=1227925489 066&isSearch=false
I know argos do the challenge line of drills (they did have a cheap 14.4v drill but seemed to have stopped doing it now) but have been looking around to get as much power for as little and as simple as possible
Any help on the matter would be gratefully receieved
Chris
ps. did try posting them as hyperlinks but kept getting The formatting code newurl requires 2 argument(s); you provided only 1 argument(s).
