Feather weight crusher
    I dont see any problem. Lets go for it.
      Could be intresting you get in first im OOTA if I get in first well depends where I grab you should be fun
        You seen the vids yet Dan links at top of page
          just stick some hardox on top of your bot :P
            just dnt let the front of his robot face u :P
              Thats right, there are 3 other sides to attack besides the front.
                have a wedge on every side of your robot then the crusher will just slip down
                • #23
                  To make sure grease up the wedges as well. Now would that count as a consumable?
                  • #24
                    Long or not that thing is sick. In a good way.
                    • #25
                      how much did it cost tony, just the linear actuator and did you get it from ebay?
                      also what is your claw made from and how did you make it?
                      cheers alex
                      (Message edited by psycho fling on October 07, 2007)
                      • #26
                        Hi Alex.
                        The actuator cost £73 of Ebay.
                        The claw is made from 3mm steel. It was made in 4 bits. 2 side pieces and a top and bottom piece welded together. I also welded soom internal braces in it. the tips can be changed as they slot in to the end of the claw. The tips are made from 8mm Ti. Got some tips for comps and some flat tips for whiteboards.
                        • #27
                          Hi Guys
                          Pic of latest creation on profile.....
                          2 of the best crushers around kan-opener and razor
                          joined together.....meet KANZOR !!!
                          Wot fun !!
                          Cheers Froggy
                          • #28
                            Love it! It looks really great Tony.
                            • #29
                              Nice one Tony
                              • #30
                                is ebay the best place or can you buy direct from linak? also tony were you bidding or buy it now on the one you purchased?
                                thanks alex
