Radio signal
BAD memory Ed.
The correct calculated length for a 1/8th wavelength 40Mhz R/C antenna is I believe 89cm ... 1/4 wave being 178.3cm.
Robert can you do a range check with the receiver OUT of the bot and working just a servo?
(Message edited by woody on August 05, 2007)
					BAD memory Ed.
  , the antenna in the middle, and a nice wiremesh shield around it to stop outside interference. It helped a lot.
