hi all
i currently run 3x 7.2v 2100mah nicad packs in my robot, these run 2x 18v drive motors and a 12v lifter motor (all drill motors. just wondering because i only have the one set it takes a while to charge, but i do have 2x 8.4v 3300mah nimhs from my other bot, just thought if i bought another of the nimhs same spec could i use those to run the above setup when my primary packs are charging?
What i mean is will the voltage be to high, and when in competitions will it be allowed because of these packs being heavier?
thanks alex
thanks alex
