Electronize electronic switcher
This topic is closed.
  • Electronize electronic switcher
    hi
    rewiring my lifter motor micro switches and the electronic switcher, bit stuck becuase, i know that the Nc goes to the power but does one go to the postive of the power distributor and the other to the negative? if yes which way around?
    i have put a pic on my site, robot improvements
    http://www.psychoflingteam.co.ukwww.psychoflingteam.co.uk
    alex
    put a better explanation next to the picture, might help
      Email sent with pic.
        reply sent
          i have found some instructions that i think might help on the technobots site, but it isnt working the download i mean, could someone see if it works for them and email it to me? i dont know if this is the problem but technobots have discontinued the zeobot range
          anyway if anyone has any luck please post
          cheers alex
            its ok now i have got it to work! (the download)
              i have got the lifter working, well working as in the mechanism moves up and down at quite a fast speed, although i seem to be getting a bit of interference which make the lifter motor move in bits, any ideas? also when the lifter is working the drive mototrs seem to twitch?
              any thoughts welcome, i wont be able to respond for over a week as im off on my hols
              thanks alex
                only one way to sort it out in an instant - Buy a DX6
                It will more than likely be that the motor used for the lifter is giving off alot of noise. Capacitors on the back of the motor usually do the trick.
